Ceiling Vent Location. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 07:46 PM   #1
Rewards Points: 24
Ceiling vent location.
We are remodeling the lowest living level of our 4 level split. The basement is the lowest level. We live in Northeastern Ohio. The level we are remodeling in built on a slab and has the existing HVAC supply lines run through the slab. The supply lines are in very poor condition as very little air comes out of them. As a result, I plan to move the supply lines to the ceiling as I really do not want to go through all of the time and expense of busting up the slab and replacing the supply lines. There is an existing supply trunk that runs through the ceiling of the lower level, which supplies service to the upstairs. I plan to use this supply trunk for the ceiling branches.
My question is what is the best placement for the ceiling vents? Should they be located by the interior wall or the exterior wall? If interior wall, should they come from the ceiling or at the top of the all. If the exterior wall, how far from the wall should they be?
I have included a picture of the layout of the lower level. The supply and return lines are located in the ceiling.
jman2012 is offline   Reply With Quote
Old 11-21-2012, 03:32 PM   #2
Special User
Rewards Points: 1,230
Generally, outlets are placed near windows, as that's usually the coldest part of the room. The best place is in the floor, as heat rises. Second best is in the wall. Worst place is in the ceiling. If you install ceiling outlets, consider adding a ceiling fan to circulate the air. Or keep the undersized floor vents and use both sets simultaneously.
Returns are usually placed on the opposite side of the room from the outlets to force the warm air to travel as far as possible.
The vents in our previous house (1980s construction) were about 12" from the exterior wall. In our current house (1970s construction) they're like 3" from the wall. Not sure what the ideal distance is, though. 12" looks better to me.
tylernt is offline   Reply With Quote
direct vent water heater location BlueBSH HVAC 7 12-17-2012 01:20 PM
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
How to extend HVAC ceiling vent through new soffit? NewHomeDIYGuy HVAC 33 03-26-2012 08:59 AM
Birds bathroom vent mess Wheats General DIY Discussions 0 11-28-2010 08:04 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
