Ceiling Return Addition Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2014, 04:21 PM   #1
Rewards Points: 66
Ceiling return addition question
Last year I added an 8 inch flex duct ceiling mounted return in my sons den. Want to add another in the formal living area in the room next to this den.
As I stated this was a simple 8" flex back to the return for the den. Can I add another ceiling return in the adjacent living room and use a 8x8x8 wye to connect them all together?
If I dont upsize the main line back to the return air plenum, will I loose much return?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 07-28-2014, 08:29 PM   #2
An old Tradesmen
Rewards Points: 7,328
You;ll reduce the amount of return the first one has.
Best to increase the line back to the furnace/A/C to 10".
The Following User Says Thank You to beenthere For This Useful Post:
digitalplumber (07-28-2014)
asbestos in popcorn ceiling (new air return for furnace) MysteryWhiteBoy HVAC 7 02-09-2013 12:32 PM
Insulate / vapor barrier drop ceiling question joeh Insulation 9 01-10-2012 10:56 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
return plenum and a drywalled basement ceiling 06bluez HVAC 1 11-25-2009 04:41 PM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 10:54 PM
