Ceiling Damage Ductwork Condensation/Water (not In Attic)... - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 03:54 PM   #16
An old Tradesmen
Rewards Points: 7,760
Originally Posted by Fairview View Post
I respectfully disagree. Increasing the air temperature 4 increases duct temperature via return air therefore decreasing the chances of reaching dew point.
The space between the first floor ceiling and second floor's floor. Is probably at 78F and 55% RH, or higher. If the return air temp is 74, and the temp difference across the coil is 20 degrees. making the supply duct 54F. It will still sweat, as the dew point or the conditions I posted is 60.5F. Even if the temp difference between supply and return ws only 14 degrees, the supply duct would be 60, so just under dew point.
Question: BNC cables through attic (studs to wall, or ceiling drywall?) eatmyturf Electrical 4 04-05-2013 10:25 PM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Water Damage: Repairing Ceiling Drywall Defects at Seams? Lovegasoline Drywall & Plaster 5 04-24-2012 06:57 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
