Cat Box Aroma Going Through Vents Into House - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 11:27 AM   #1
Cat box aroma going through vents into house
I have cat boxes in the basement and the smell from them goes up the ducts. Is there anything I could put into the ducts so that the vents do not get the cat box aroma. I have a heat pump and that is what I use for my heat and air. Please help.
jal044 is offline   Reply With Quote
Old 09-20-2012, 11:38 AM   #2
JJboy's Avatar
move the cat box or get a dog.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following 2 Users Say Thank You to JJboy For This Useful Post:
ben's plumbing (09-20-2012), sublime2 (09-20-2012)
Old 09-20-2012, 11:48 AM   #3
Clean the kat box more often
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
Old 09-20-2012, 11:53 AM   #4
how
Rewards Points: 1,102
I put a small computer fan in a flexible dryer vent and ran it from above the cat box to the outside.
how is offline   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (09-20-2012), jal044 (09-20-2012)
Old 09-20-2012, 12:41 PM   #5
I would first check to make sure the litter box is not near any returns...
allthumbsdiy is offline   Reply With Quote
The Following User Says Thank You to allthumbsdiy For This Useful Post:
Missouri Bound (09-21-2012)
Old 09-20-2012, 02:25 PM   #6
biggles's Avatar
if you have no supply ducts cooling the basement then why are you pulling basement air into the house return should be from the 1st floor conditioned space...if you have anything sucking return air with the fan on in that basement block it off.
The Following User Says Thank You to biggles For This Useful Post:
Old 09-21-2012, 02:48 PM   #7
Rewards Points: 156
I am thinking your cat litter box is in the basement near the HVAC system. If that's the case, check and make sure all the doors are properly installed on your air handler, and that the gaskets are not leaking, and drafting air into the unit. I would also check for duct leaks on your returns. Purchase a small bucket of "mastic" or air duct sealant. (it's a gray puddy looking stuff) from the hardware store and seal any leaks you find. The easiest way to find air duct leaks in an intake duct I have found is to take a small piece of paper and run it across any joints. If the paper sticks, you have a leak!
av-geek is offline   Reply With Quote
Old 09-21-2012, 02:55 PM   #8
Rewards Points: 266
Smartscoop
Litter-Robot
Scoopfree
ionized is offline   Reply With Quote
Old 09-21-2012, 03:59 PM   #9
as seen on tv
Rewards Points: 150
hvac guys love kittie pans
qbert is offline   Reply With Quote
Old 09-21-2012, 08:22 PM   #10
Yep. Nothing could be better than working right next to a couple litter boxes, even better is when kitty comes down and drops off a fresh load.
I do kind of enjoy when the burners and heat exchanger rust out five times faster then they should from the litter box fumes. Caching $! Sorry that was mean
Condensation from vents under house in crawl space DIY Kathy HVAC 1 09-02-2011 10:27 AM
Uneven air distribution through vents in house Zombify HVAC 1 04-28-2010 01:45 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
