Cast Iron Rad Leak - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 06:38 AM   #1
Rewards Points: 85
Hey! Hope everyone is having a great new year so far!
My q is with regards to an old cast iron radiator in a guest br. I've noticed water running from out under It the other morning. I look and notice a slow drip in what looks like a joint between fins at the bottom. . Can this be fixed w/o having to drain the system and stand on a two ft long pipe wrench to break the rad loose? Maybe some high heat sealant?? The system is steam heat. Your suggestions are appreciated.
Best!!
JohnC20 is offline   Reply With Quote
Old 01-08-2013, 07:32 AM   #2
Roofmaster
Rewards Points: 2,210
No, I dont see how anything is going to resist hot steam under pressure. You cant caulk a boat from the inside.
Old 01-08-2013, 03:42 PM   #3
Rewards Points: 85
My thoughts were that as well. But it's not steam that is coming out as I am able to touch the area where it is dripping. I was wondering maybe some boiler putty or some kind of dealer.
Old 01-08-2013, 03:44 PM   #4
Rewards Points: 13,748
Any thing applied on the outside is not going to work.
Your seeing water because the steam is cooling.
Old 01-08-2013, 03:56 PM   #5
An old Tradesmen
Rewards Points: 7,378
Be very very careful. Take your wrenches and give the bolts(that hold the rad together) a slight snug and see if that stops it from leaking.
The Following User Says Thank You to beenthere For This Useful Post:
joecaption (01-08-2013)
Old 01-08-2013, 06:45 PM   #6
Rewards Points: 6,652
There are Architectural warehouses, that you can purchases reclaimed rad's, etc. that are pulled from old structures before razed. Here is one company I found through a Yahoo search http://www.oldcastironradiators.com/ Keep in mind, that piping is as old as the Rad, and since it rusts from the inside out, you may find that you are opening up a large can of worms, once you start working on it.
Old 01-08-2013, 07:10 PM   #7
bbo
I remember researching the rads ( Hw) in our old house.
preferred method of repair is to take rads apart, clean all edges, and reassemble.
easier to buy a reclaimed (pressure tested of course) or have someone who does repair repair it. very easy to crack cast iron if not careful.
bbo is offline   Reply With Quote
Old 01-08-2013, 07:19 PM   #8
Roofmaster
Hey Beenthere, should he hit the nuts with PB Blaster for a couple of days prior to trying?
Old 01-08-2013, 07:33 PM   #9
An old Tradesmen
Not really. Won't hurt.
Old 01-08-2013, 07:39 PM   #10
Rewards Points: 85
Thanks to everyone. I will try to tighten the nuts first...
Old 01-08-2013, 07:50 PM   #11
Roofmaster
I dont get that answer at all. Not really, Wont Hurt.
I think he ought to wire wheel down through the 6,580 coats of paint that is always on old radiators, and try to get some PB-Blaster into the threads. Maybe even heat them up a little? Carefully, so no crack?
Old 01-08-2013, 09:21 PM   #12
An old Tradesmen
Thats why I didn't tell him to really torque hard on them.
Old 01-09-2013, 06:42 AM   #13
Rewards Points: 1,216
Listen to gregzoll and replace it, your looking to get burnt or open up a can of worms that you won't be able to close.
Make sure you have all the wrench's, fittings and new radiator before your mess with it.
Or call a Pro.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Connecting brass trap to cast iron (Noob) acr2001 Plumbing 7 08-22-2012 12:37 AM
Help with old, rusted cast iron toilet flange BigWinston Plumbing 7 08-08-2012 09:02 AM
pinhole leak in cast iron elbow for water heater. tractorfarmer HVAC 23 01-16-2012 05:21 PM
Bathtub Recommendations - Cast Iron or other? HandyFrank Plumbing 5 10-25-2011 03:25 PM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 07:41 PM
