Cast Iron To PEX Hydronic Boiler? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 01:04 AM   #1
cast iron to PEX hydronic boiler?
I have a gravity fed boiler radiator system, the previous owner capped off one of the runs that was heating the bathroom (due to the placement of the rad where they knocked out a wall).
They put in a very underpowered electric baseboard heater and of course the floor is freezing and I have to use a spaceheater in winter.
Since there is a supply and return line still underneath the floor in the basement, can I pipe this into pex somehow and make a subfloor heating system? The floor area in the bathroom is only 48sqft and the joists are 24" OC.
Would it be cheaper/easier to just buy one of the in-floor heating matts from costco and connect it to the circuit that the baseboard heater is on?
toohfo is offline   Reply With Quote
Old 01-25-2012, 01:14 AM   #2
Rewards Points: 14,312
Is the floor insulated? If not just insulate it with R-19.
Are all the holes sealed with foam where the water and electric lines were run through the plates.
Far cheaper to just buy a longer electric base board.
Old 01-25-2012, 04:34 PM   #3
The floor isn't insulated! My brother-in-law has some 4" foam cut-offs from a construction project that I can use for that. Thanks for the suggestion!
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 03:42 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Hi & Low Limit setting - Oil boiler, forced HW - Cast Iron radiators Scuba_Dave HVAC 40 01-10-2010 01:39 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
