Carrrier Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 01:57 PM   #1
Carrrier Furnace
Cycles on and off. Model number MCB120-10120
George C is offline   Reply With Quote
Old 11-24-2012, 01:59 PM   #2
What can I check for. The furnace cycles on & off
Old 11-24-2012, 04:02 PM   #3
how
Rewards Points: 1,104
cycles on and off doesn't tell us much. Main Gas cycles on & off/ ignition?/ main blower?
or
Can you see a blinking diagnostic light through an inspection port?
What are you seeing and hearing in the furnace when you turn up the thermostat?
how is offline   Reply With Quote
Old 11-24-2012, 04:20 PM   #4
Rewards Points: 582
hey george were you go.....need more info as how stated....ben sr
Old 11-24-2012, 05:02 PM   #5
JJboy's Avatar
Good for the furnace. Turn off and open the windows
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
