Carrrier Blower Wont Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 01:25 PM   #1
Unhappy
carrrier blower wont shut off
I have an old Carrier furnace model 58gp125-2. The blower motor wont shut off. I've checked the thermostat wires on both ends no loose or touching wires. The thermostat is turned off fan set on auto. Ive tried turning off all the power to the unit and turned it back on, no luck. I also looked for a reset button, none visible. Any suggestons.
tryitonce is offline   Reply With Quote
Old 10-10-2010, 01:53 PM   #2
An old Tradesmen
Rewards Points: 8,170
Air filter probably is/was dirty and restricted air flow too much. And the limit switch is now stuck open.
Old 10-10-2010, 02:32 PM   #3
Carrier blower wont shut off
Changed filter, still running. Should limit switch automatically reset?
Old 10-10-2010, 03:03 PM   #4
An old Tradesmen
Normally it would.
But, after so many times it won't. And it needs to be replaced.
how bad was your air filter?
Old 10-10-2010, 03:08 PM   #5
Not bad was changed back in late july.
Old 10-10-2010, 03:13 PM   #6
An old Tradesmen
Supply houses, Grainger and others will be open tomorrow for you to het a new limit switch.
Old 10-10-2010, 03:55 PM   #7
I will do that thanks a lot
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Blower will not shut off. lj4 HVAC 14 12-11-2011 02:16 AM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 09:14 PM
blower won't shut off on new gas furnace johnny67 HVAC 36 09-14-2009 09:23 PM
Replaced blower motor in 58MVP now it wont shut off robr1 HVAC 4 12-19-2008 06:21 PM
