-   -   carrrier blower wont shut off (http://www.diychatroom.com/f17/carrrier-blower-wont-shut-off-83552/)
tryitonce 10-10-2010 02:25 PM
I have an old Carrier furnace model 58gp125-2. The blower motor wont shut off. I've checked the thermostat wires on both ends no loose or touching wires. The thermostat is turned off fan set on auto. Ive tried turning off all the power to the unit and turned it back on, no luck. I also looked for a reset button, none visible. Any suggestons.
beenthere 10-10-2010 02:53 PM
Air filter probably is/was dirty and restricted air flow too much. And the limit switch is now stuck open.
tryitonce 10-10-2010 03:32 PM
Carrier blower wont shut off
Changed filter, still running. Should limit switch automatically reset?
beenthere 10-10-2010 04:03 PM
Normally it would.
But, after so many times it won't. And it needs to be replaced.
how bad was your air filter?
tryitonce 10-10-2010 04:08 PM
Not bad was changed back in late july.
beenthere 10-10-2010 04:13 PM
Supply houses, Grainger and others will be open tomorrow for you to het a new limit switch.
tryitonce 10-10-2010 04:55 PM
I will do that thanks a lot
