Old 05-24-2009, 12:05 PM   #1
Unhappy
Carrrier Blower motor not running
Hi, I have Carrier AC unit air handler model FK4CNFC002. The blower is not running. I found an intermittent thermostat fan line that was probably making the motor turn off and on a lot. The motor is a 1/2 HP GE with the markings CN02 2A17 on it. How do I verify if it is the motor or the attached control module that has the problem? Can the two parts be bought separately?
wadomo is offline   Reply With Quote
Old 05-24-2009, 12:18 PM   #2
Hvac Pro
If it is an ECM motor then no, you have to buy the 2 parts together. They are tricky to troubleshoot as you need the factory technical info and a simulator. Best to call a Carrier tech. Sometimes the problem is that wiring harness and/or the circuit board. I doubt if you want to start expensive parts changing/guessing.
Old 05-24-2009, 12:54 PM   #3
An old Tradesmen
Best to have someone that knows how to diagnose that motor and module.Could also be the air handler control board.They're expensive to just replace until you get the right part.If its a ver 2.3, its probably out of warranty.if its a ver 2.5, its probably still in warranty.How old is the air handler.
Old 05-24-2009, 01:26 PM   #4
for what its worth im pretty sure you can now buy the motor control seperatly as i have changed them on carrier equip. but again proper diagnosis is essential
kennzz05 is offline   Reply With Quote
Tags
blower motor, carrier, icm
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
Ruud blower keeps running jmt HVAC 1 11-22-2008 08:33 PM
Ruud Blower keeps running jmt HVAC 2 11-21-2008 10:04 PM
furnace blower constantly running HELP! ice_wolf69 HVAC 16 10-26-2008 07:11 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 04:57 PM
