Carrier Zone Control Setting Question - HVAC - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 12:06 PM   #1
Rewards Points: 129
Carrier zone control setting question
I have the Carrier Zone Control II system. One of the settings is listed as: "Temperature Offset Adjustment" with the description stating: Each zone temperature reading can be offset by up to + or - 5 degrees. The offset is added to the actual zone temperature to produce the offset zone temperature.
What does this feature do?
jeepgrady is online now   Reply With Quote
Old 03-15-2013, 01:55 PM   #2
HVAC Tech/Owner
Rewards Points: 604
It for when your customer has some cheapo hand held temp meter and thinks the thermostat is wrong....
Its reading 2 degrees too low? Let me fix that so it matches you ACME thermometer.
Technow is offline   Reply With Quote
Old 03-15-2013, 10:23 PM   #3
Rewards Points: 446
It's also a way of convincing someone that is always saying, but if I could just set it to 72 I'd be warm. You put the offset into it and say go ahead.
old_squid is offline   Reply With Quote
Dip switch setting on Carrier Infinity 96 Furnace jeepgrady HVAC 17 12-10-2012 05:26 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
Controlling a Carrier Comfort Zone II with a PC masterchief General DIY Discussions 0 08-30-2010 12:39 PM
HVAC very weak upstairs with zone control installed g8rben HVAC 5 06-14-2009 06:51 PM
Carrier Control Board Fuse Blows kdljet HVAC 5 03-11-2009 09:20 PM
