-   -   Carrier zone control setting question (http://www.diychatroom.com/f17/carrier-zone-control-setting-question-174595/)
jeepgrady 03-15-2013 12:06 PM
I have the Carrier Zone Control II system. One of the settings is listed as: "Temperature Offset Adjustment" with the description stating: Each zone temperature reading can be offset by up to + or - 5 degrees. The offset is added to the actual zone temperature to produce the offset zone temperature.
What does this feature do?
Technow 03-15-2013 01:55 PM
:laughing: It for when your customer has some cheapo hand held temp meter and thinks the thermostat is wrong....:thumbup:
Its reading 2 degrees too low? Let me fix that so it matches you ACME thermometer.
old_squid 03-15-2013 10:23 PM
It's also a way of convincing someone that is always saying, but if I could just set it to 72 I'd be warm. You put the offset into it and say go ahead. :thumbup:
