Carrier Weathermaker Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 12:28 PM   #1
carrier weathermaker won't stay lit
I'll start with the startup process. First of all the blower is always on high, I push the reset button turn the thermostat and the gas knob on. The inducer starts turning and about 10-15 seconds after that the blower turns off. The HSI starts glowing red and then the gas relay is tripped by the controal unit and the burners turn on, about 65 seconds of the burner being on the blower starts back up and about 10-15 seconds after that the burners shut off and the blower is stuck on. if i turn the thermostat blower position to off it keeps going. I tried moving the sensor out of the way of the flame and the burners only stay on for about 3 seconds. I initiated the self test feature and I herd all the relays on the controal unit turn on and off with the accompanying devices when applicable. Why won't my bruners stay on and why won't the blower turn off, I have a feeling the two problems are related.
Thanks in advance
Nick
I get no flashing led on the controal board and if the unit's power switch is turned off and turned back on while the thermostat is off the blower still turns on high.
NDELEON is offline   Reply With Quote
Old 10-19-2010, 03:45 PM   #2
HVAC / Plumbing
If you aren't moving enough air across the heat exchanger ie, dirty filter or coil. The high limit could be opening & turning the burners off. If the limit opens the blower will come on. the chamber cools down limit closes & the process starts over again. Others will give opinions / advise when they log on
kenmac is offline   Reply With Quote
Old 10-19-2010, 04:38 PM   #3
The air filter has been ruled out; however, I do not know how to find out if it is a dirty coil as you say. The blower will never turn off by itself if I don't turn it off, or reset the system with the switch it just stays on. I don't know if you were clear on that based on your reply.
Old 10-19-2010, 05:01 PM   #4
HVAC / Plumbing
.Problem Maybe at t.stat..Try Disconnecting wires at t.stat. Jump out the r & w at the t. stat & see if the results are the same
Old 10-19-2010, 05:43 PM   #5
I disconnscted the T.stat and jumped R and W to no avail I got the same result.
Old 10-19-2010, 05:50 PM   #6
HvacWiz's Avatar
Rewards Points: 252
Is the limit that is tripping located on the burner box?
HvacWiz is offline   Reply With Quote
Old 10-19-2010, 06:07 PM   #7
im not sure what is tripping to turn the burners off the reset button is on the side of the burner box.
Old 10-19-2010, 06:15 PM   #8
HvacWiz's Avatar
Rewards Points: 252
If that is the case, sounds to me like the secondary heat exchanger is plugged and will need replaced. This will be under carriers warranty but labor to do job is not covered.
Old 10-19-2010, 06:35 PM   #9
HVAC / Plumbing
Sounds like your burners are cutting off on limit. You need to call a pro to check it / repair Like stated above possibly stopped up secondary. cracked primary or dirty coil. how old is the furnace ?
Old 10-19-2010, 07:18 PM   #10
it's about 15 years old
Old 10-20-2010, 07:34 AM   #11
I just reset it this morning and it has been on since.
carrier weather maker won't stay lit NDELEON Appliances 2 10-19-2010 12:24 PM
Carrier Weathermaker 8000 help please TenTwelve HVAC 2 01-11-2010 05:49 PM
Carrier Weathermaker 9200 58MXA080-16 Cosmo HVAC 7 03-09-2009 03:15 PM
Carrier won't stay lit kurto HVAC 10 12-13-2008 01:50 PM
Weathermaker 9000 Carrier Code 31 problems HELP!! Its cold dynekcl HVAC 6 11-09-2008 03:15 PM
