Old 11-11-2010, 11:31 AM   #1
Carrier Weathermaker SXi Codes 41 and 44
Hi,
I have a Carrier Weathermaker SXi. I woke this morning to a cold house. When I checked the furnace, I noticed the error codes 41 and 44. The codes are "blower outside valid speed range" and "blower calibration fault" respectively. After powering the furnace off and turning it back on, it tries to start up and gets as far as giving me a solid yellow light indicating the furnace is operating in high heat and after about 60seconds, the furnace shuts down and shows codes 41 and 44 again. After leaving the furnace alone for awhile, I returned to it and it was giving a code 12 "blower calibration lockout". I again powered it off and on and once again it started up got to a solid yellow light and shut down after about 60 seconds of operating in high heat. While I was typing this, without touching it, the furnace attempted to start up again on it's own and got as far as a solid yellow light once again and after a 60seconds shut down giving code 33 "high limit fault". Does anyone have any insight as to what might be going on? Also, if it is just that the blower motor needs to be calibrated, is that something that can be done fairly easily or does an HVAC guy need to be called and what should I expect the cost to be for someone to calibrate it? Thanks in advance for any responses.
Knight78 is offline   Reply With Quote
Old 11-11-2010, 12:21 PM   #2
Hvac Pro
That is a really old unit and it has a first generation ECM (electronically commutated/controlled motor) with a circuit board in it. VERY expensive to replace. Lots of heat exchangers failing on those units and I would invest my $$ in a new unit. May want to get a Pro to check the heat ex and assess it but be prepared for bad news.
Old 11-11-2010, 07:58 PM   #3
If the HX has failed, what can the poster expect to get from Carrier because it has failed. I recently replaced a 20-year old Weathermaker SX (not SXi) and noticed, after I had removed it to install the new one, that my secondary HX was failing. There was corrosion and junk on the outside and along the joints.
At that point, for me, it was too late, because I had already purchased a new Bryant for a replacement. Had I discovered before buying a new one, would the typical manufacturer with a lifetime HX warranty provide a new, similar furnace?
civiltoatee is offline   Reply With Quote
Old 11-11-2010, 10:37 PM   #4
HVAC / Plumbing
Life time .. would mean the life of the unit or until it's no longer produced. If the unit is no longer produced. that's the end of the units life or life time
kenmac is offline   Reply With Quote
Old 11-12-2010, 07:09 AM   #5
Professional
there is a bulletin for similar units..... have a pro check heat exchanger......don't know if yours is covered under bulletin. I think they give you money towards replacement unit of same brand
hvactech126 is offline   Reply With Quote
Old 11-12-2010, 07:18 AM   #6
Hvac Pro
They give you the heat exchanger and you pay for the labor to install it. Apparently the exchanger is still available. Labor may be up to $1000 plus his $1000 in motor replacement/circuit board problem. Hardly worth it IMO.
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 08:04 PM
Carrier Weathermaker SX mikeschu HVAC 1 11-01-2010 05:13 AM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 07:30 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 01:44 PM
Carrier code 31 on 58MXA (WeatherMaker 9000?) SteveAnnArbor HVAC 7 11-05-2007 07:53 PM
