Carrier Weathermaker Furnace SKI - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 12:33 PM   #1
My furnace is operating however the exhaust stinks and is causing a yellow stain on the exhaust vent. The unit has two error codes -31 high pressure switch fault, and 44 blower calibration fault. 10 years ago I had a bad motor, and had it replaced, the circuit board and motor were separated at that time for ease of replacement in the future. Otherwise the furnace runs in high heat mode as usual.
troubles is offline   Reply With Quote
Old 01-04-2011, 02:51 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
good chance there is something wrong with the heat exchanger if the furnace uses pvc flues. Have it looked at by a pro.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Carrier Pro help in interlocking a Weathermaker Infinity 58MVP to a Lifebreath HRV crankcase HVAC 1 12-18-2010 06:52 AM
Carrier Weathermaker SXi Codes 41 and 44 Knight78 HVAC 5 11-12-2010 06:18 AM
Carrier Weathermaker 8000, Gas Furnace Problem kiss44 HVAC 1 10-18-2009 08:27 AM
Trouble Shooting a Carrier 9200 Weathermaker Furnace JoeDell HVAC 4 01-08-2009 04:07 PM
