Carrier Weathermaker 9200 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 01:54 PM   #1
Question
Carrier Weathermaker 9200 problem
I have a little problem. It happen about every three days or a week. My furnace will try to come on . Meaning that the draft induction motor will start, run about 10 to 15 seconds then cut off. About 20 or 30 seconds it will try again and do ok. Sometimes it does not try again. I have at first thought it was the thermstat because you could just tap on it and then it would go ahead and work then i found a loose wire at the control board on the furnace and thought that this was the problem but now i am still having problems. Somestimes when it is calling for heat and nothing is working i go to the furnace and just the bump of removing the cover will start the draft induction motor and again somestimes i can just bump the furnace and it will start. Sometimes i can just turn off the power and back on again and the blower motor will come on and run for about a minute and then the draft motor will come on and the furnace will light and work ok for days. what could be wrong now?
lemsouthside is offline   Reply With Quote
Old 02-05-2011, 04:35 PM   #2
Rewards Points: 508
Make sure filter is clean.
Next, if you're lucky, it's a dirty flame sensor (not the ignitor). Here's how to clean. After you find it, check its connection before cleaning. Then try cleaning it.
YouTube: http://www.youtube.com/watch?v=I86jo...eature=related
diyorpay is offline   Reply With Quote
Old 02-05-2011, 04:39 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
check for a flashing code through the blower door window while the unit is acting up. This will help us to help you. A legend should be on the blower door or the back of the big door.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-06-2011, 07:00 AM   #4
I will check for a code but this may take a few days before it happen again.
Trouble heating house w/ Carrier Weathermaker Infinity adam_murphy HVAC 2 01-09-2011 07:51 PM
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 12:07 PM
Carrier 9200 Heat Exchanger? River Camper HVAC 20 12-18-2010 09:48 PM
Carrier 58MXA pressure/vacuum problem gshock HVAC 8 01-17-2008 06:13 PM
Carrier Weathermaster 9200 flame roll-out switch problem jamesbond HVAC 4 12-05-2007 06:55 AM
