Old 12-23-2009, 12:52 PM   #1
Carrier Weathermaker 9200 problem
Thanks in advance for any help here. The problem is only about 3 times in the past month, the furnace would not come on. It shows code 14. I turn off power and restart and then it works fine. What would cause this, so infrequently? I noticed that all 3 times have been around 8 or 9 PM and on windy nights with big temp drops, if that matters.
alinniles is offline   Reply With Quote
Old 12-23-2009, 09:46 PM   #2
The flame sensor may be slightly fouled. May need cleaning,
SKIP4661 is offline   Reply With Quote
Old 12-23-2009, 10:08 PM   #3
Thanks Skip. I will give that a try. It stopped working about an hour ago but, restarted it ok
Old 12-03-2012, 08:13 PM   #4
We are looking to see where the flame sensor is??? Is it in the burner box? Our system comes on and the fan works, then you hear clicking but nothing starts up? We want to clean it, just not sure where it is
jrobins1 is offline   Reply With Quote
Old 12-03-2012, 08:31 PM   #5
jrobins1 go back and add your own post.
Carrier Weathermaker 9200 58MXA080-16 Cosmo HVAC 7 03-09-2009 04:15 PM
Trouble Shooting a Carrier 9200 Weathermaker Furnace JoeDell HVAC 4 01-08-2009 05:07 PM
Carrier Weathermaker SX Problem hchampagne HVAC 2 09-23-2008 10:48 PM
Carrier 58MXA pressure/vacuum problem gshock HVAC 8 01-17-2008 07:13 PM
Carrier Weathermaster 9200 flame roll-out switch problem jamesbond HVAC 4 12-05-2007 07:55 AM
