Old 06-29-2009, 09:49 PM   #1
Default Carrier Weathermaker 9200 for LP/Nat?
My cousin is offering me a sweet deal on a HVAC system he bought for his home, but apparently never installed. It seems he lost his job, and then his home, and doesn't want to install it into the rental where he lives now.
Its a Carrier Weathermaker 9200 with 4 ton A coil unit. It has the inside Air handler – Gas Heat exchange -6” micro filter – outside compressor and disconnect (with whip).
He says it is setup for LP gas, but can easily be converted to natural gas (which we use).
Is something like this worth $300? Does anybody know if this unit is currently being manufactured?
My house is 22+ years old, and I think I'm going to need a new furnace / AC fairly soon.
Mike
1Mike is offline   Reply With Quote
Old 06-29-2009, 10:26 PM   #2
Master Plumber/Mechanical
A sweet deal is not so sweet when not properly sized and installed improper.
What is the sq ft of your house?
Old 06-29-2009, 10:28 PM   #3
i work for a carrier dealer and it is easy to convert to natural gas. any carrier delaer should be able to order it for you and it is a hell of a deal but plumber1 is right it needs to be sized to your house
tcbaker72 is offline   Reply With Quote
Old 06-29-2009, 11:22 PM   #4
2550sq ft on two levels.
I'll pay to have it installed if that's necessary. I installed a FAG / AC in a house I owned about 25 years ago. I talked to the current owner recently and they said it is still running fine. But I know a LOT has change since then. In reading some of the threads here I've noticed a lot of terms I don't recognize- like "seer"?
Mike
Old 06-29-2009, 11:28 PM   #5
If you are talking 2 levels meaning main floor and basement then IMHO you will be oversized for 4 tn A/C
If you are talking main floor and 2nd story floor then you may be slightly undersized for 4 tn A/C
See if you can post the model number of your current A/C this will tell me what you have now to see if you are close
You may want to contact a local contractor for sizing
Researching like you are doing is better than spending $300 for a system that can only be used for a boat anchor
Old 06-29-2009, 11:37 PM   #6
Yeah, I want to do it right, even if it means spending more.
Its a frame house, with 1st floor and 2nd floor, no basement. HUGE crawl space (should've been a basement) is where the furnace is located.
I'm 6ft tall, and I can easily stand in the crawl space.
Old 06-29-2009, 11:39 PM   #7
Can you post your current a/c model number
Old 07-01-2009, 10:02 AM   #8
I can't find any numbers on it. Its really old! Where would I look?
Tags
carrier weathermaker 9200
More On This Topic
Hi, I'm Emily Larew. We're on counts one through four on our hip hop series. So, we're going to do a crawl forward and a knee lunge. So, we just bang the floor here on eight, alright? We're going to crawl forward with our right hand leading out and we're... Read More »
Did you move into a house and find stray cats on the back porch, in the garage, basement, outbuildings or crawl spaces? If you don’t want any feral felines hanging around, here are some steps to convince them to move on. Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com. Today I am going to show you how to prep up the floor for a new installation for flooring in your basement. The first thing we are going to be using is a floor scraper. Second thing we... Read More »
Clean Up after a Flood
Clean Up after a Flood by Expert Village
I'm James Donnelly for Expert Village and today I am going to show you what you might need in case of a flood emergency. Do not stack sandbags around the outside walls of your house to keep flood waters out of your basement. Flood waters seeping down... Read More »
The United States grants visas (permission to stay for a long time period) to non-citizens for many reasons. One such visa, called a TN visa, allows Mexican and Canadian citizens to work in the United States under the North American Free Trade Agreement... Read More »
Seasonal maintenance on Carrier 9200 gshock HVAC 4 04-12-2009 11:19 PM
Carrier Weathermaker 9200 58MXA080-16 Cosmo HVAC 7 03-09-2009 05:15 PM
help carrier weathermaker 9200 model 58mxa mjshea HVAC 4 02-05-2009 12:51 AM
Trouble Shooting a Carrier 9200 Weathermaker Furnace JoeDell HVAC 4 01-08-2009 06:07 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 02:44 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
