-   -   Carrier Weathermaker 9200 for LP/Nat? (http://www.diychatroom.com/f17/carrier-weathermaker-9200-lp-nat-47773/)
1Mike 06-29-2009 08:49 PM
My cousin is offering me a sweet deal on a HVAC system he bought for his home, but apparently never installed. It seems he lost his job, and then his home, and doesn't want to install it into the rental where he lives now.
Its a Carrier Weathermaker 9200 with 4 ton A coil unit. It has the inside Air handler Gas Heat exchange -6 micro filter outside compressor and disconnect (with whip).
He says it is setup for LP gas, but can easily be converted to natural gas (which we use).
Is something like this worth $300? Does anybody know if this unit is currently being manufactured?
My house is 22+ years old, and I think I'm going to need a new furnace / AC fairly soon.
Mike
Plumber101 06-29-2009 09:26 PM
A sweet deal is not so sweet when not properly sized and installed improper.
What is the sq ft of your house?
tcbaker72 06-29-2009 09:28 PM
i work for a carrier dealer and it is easy to convert to natural gas. any carrier delaer should be able to order it for you and it is a hell of a deal but plumber1 is right it needs to be sized to your house
1Mike 06-29-2009 10:22 PM
2550sq ft on two levels.
I'll pay to have it installed if that's necessary. I installed a FAG / AC in a house I owned about 25 years ago. I talked to the current owner recently and they said it is still running fine. But I know a LOT has change since then. In reading some of the threads here I've noticed a lot of terms I don't recognize- like "seer"?
Mike
Plumber101 06-29-2009 10:28 PM
If you are talking 2 levels meaning main floor and basement then IMHO you will be oversized for 4 tn A/C
If you are talking main floor and 2nd story floor then you may be slightly undersized for 4 tn A/C
See if you can post the model number of your current A/C this will tell me what you have now to see if you are close
You may want to contact a local contractor for sizing
Researching like you are doing is better than spending $300 for a system that can only be used for a boat anchor
1Mike 06-29-2009 10:37 PM
Yeah, I want to do it right, even if it means spending more.
Its a frame house, with 1st floor and 2nd floor, no basement. HUGE crawl space (should've been a basement) is where the furnace is located.
I'm 6ft tall, and I can easily stand in the crawl space.
Plumber101 06-29-2009 10:39 PM
Can you post your current a/c model number
1Mike 07-01-2009 09:02 AM
I can't find any numbers on it. Its really old! Where would I look?
