Carrier Weathermaker 9200 Error Code 31 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-17-2012, 01:07 PM   #1
Carrier Weathermaker 9200 error code 31
Just yesterday I received an error code 31 with my Carrier Weathermaker 9200. I had the unit installed brand new back in 1999. I have been lucky over the past 5 years. However, during the first 2-5 years a lot went wrong; I had to replace about 5 Hot Surface Ignitors, 1 Pressure switch and another part that I think was called the gas valve unit. (The part had several S-shape bends; made up with 1Ē tubing; with several holes in it and at one end of the pipe there was a square control value unit,)
Now overnight, it just started receiving an error code 31. The heater stats up like normal and the exhaust blower (Item #6 under furnace components list) also starts up. However after about a minute of run time; the main blower does not start up and there is no flame visible in the sight window and then the red solid light starts blinking the error code 31.
Iím very mechanically inclined; But. Iím not sure how to test the following.
1. Inducer motor or start capacitor
2. Pressure switch and/or connection
3. Low inducer voltage
4. Obstructed pressure tubing
Can anyone please explain or point me in the right direction. I have been unable to work since last April do to taking care of my 78 year old mom and I need to fix this heater myself to save money.
Espo is offline   Reply With Quote
Old 03-17-2012, 02:24 PM   #2
how
Rewards Points: 1,104
I am assuming that fault code 31 is an air flow issue but the legend on your furnace door will verify this.
Anything that affects the air pressure through air intake, burner compartment, exchangers, inducer assy, the pressure switch, those hoses or the exhaust vent can cause that code..
The first thing to start to check is that all the small hoses connected to your inducer assy or pressure switch are crack and split free. Next check that the hoses are clear and water free. Next check for debris build up just inside the hose port inside the ID assy. Use a straightened paperclip to test 2 " inside it and to clear it if its obstructed.
The inducer normally gets tested with a manometer to check the pressure it creates at the hose bib. It might be listed on the ID assy in inches water column. A clear plastic tube attached to the ID hose bib which then drops down and loops back up beside itself and is half filled with water will usually work. When the inducer motor comes on, the total difference in height that is created in the two water levels in the water in that hose will give you the Inches water column that the inducer is producing.
Let us know what you find.
how is online now   Reply With Quote
Old 03-17-2012, 02:45 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
how (03-17-2012)
Carrier Weathermaker 9200 blower problems preacher01 HVAC 4 06-01-2012 07:24 AM
Carrier Weathermaker 9200 klrz28 HVAC 24 04-23-2011 08:37 PM
Carrier weathermaker 9200 jnspence HVAC 3 12-07-2010 12:37 PM
Carrier Weathermaker 9200 for LP/Nat? 1Mike HVAC 7 07-01-2009 09:02 AM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 01:44 PM
