Carrier Weathermaker 9200 - Blower Not Turning On. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2010, 03:32 PM   #1
Carrier Weathermaker 9200 - Blower not turning on.
I have a Carrier Weathermaker 9200 HVAC. The blower is NOT turning on -however, the outside condenser unit turns on. The relay is working because I hear it 'click' when the fan needs to turn on. I have checked the 24A Fuse - it's fine. The LED is ON. No error codes. Can someone help? Thanks, Vijay
bvijay is offline   Reply With Quote
Old 08-02-2010, 04:02 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,846
Which relay do you hear click? the fan relay on the circuit board?
Old 08-04-2010, 09:34 AM   #3
Yes, it is the fan relay that I hear.
Old 08-04-2010, 01:48 PM   #4
Hvac Pro
yuri's Avatar
Do you have any hands on electrical experience? I can tell you how to hot wire/check the motor but not if you are going to get killed in the process. Try turn the heat on and see if the fan works.
Old 08-13-2011, 08:43 AM   #5
I'm having the same issue with my furnace. Does anyone know what to do to get the blower to kick on and run when the AC is on? I can hit the reset on the furnace firebox and get the blower to run, but when I put it in auto it won't kick on when it needs too.
preacher01 is offline   Reply With Quote
Old 08-13-2011, 09:27 AM   #6
Yuri, I tried to turn on the heat and the fan kicked on like it should. Thanks for any help.
Old 08-15-2011, 07:03 PM   #7
Yuri
Same problem as preacher but fan does NOT come on when I turned on the heat. Bad control board and/or bad solder?
smoreho2 is offline   Reply With Quote
Old 08-15-2011, 07:04 PM   #8
Yuri
same problem as preacher only fan does not come on under heat either. bad circuit board and or bad solder?
Carrier 9200 weathermaker ? singlemom2 HVAC 2 01-05-2010 08:52 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 09:09 PM
Carrier Weathermaker 9200 for LP/Nat? 1Mike HVAC 7 07-01-2009 08:02 AM
Trouble Shooting a Carrier 9200 Weathermaker Furnace JoeDell HVAC 4 01-08-2009 04:07 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 12:44 PM
