Carrier Weathermaker 9200 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 12:11 PM   #1
Carrier weathermaker 9200
Hi, I have a carrier weathermaker 9200 58MXA040. I disconnected the control board to get access into the back area to replace the collector box drain tube. I am now unsure where a wire I took off goes back on the control board. It is the main electrical supply wire (black). It comes from the where the main electical cord goes into the unit. There is a white wire that runs next to it. If anyone has knowledge of these systems I would really appreciate it. I can describe it in more detail if needed as well. Thanks
jnspence is offline   Reply With Quote
Old 12-06-2010, 01:12 PM   #2
look at the wireing diagram. where it says L1 and L2 on the diagram it will have corresponding marking. black goes to L1.
hvaclover is offline   Reply With Quote
Old 12-06-2010, 01:28 PM   #3
Thanks hvaclover. I am at work but will look at it when I get home. I think you nailed tho. I will post back with an update.
Old 12-07-2010, 11:37 AM   #4
HVAClover you are the man. Thanks again. The diagram makes complete sense now. Next time I will take better notes when removing so many wires.
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 07:04 PM
Carrier 9200 weathermaker ? singlemom2 HVAC 2 01-05-2010 08:52 PM
Carrier Weathermaker 9200 for LP/Nat? 1Mike HVAC 7 07-01-2009 08:02 AM
Trouble Shooting a Carrier 9200 Weathermaker Furnace JoeDell HVAC 4 01-08-2009 04:07 PM
Problem with Carrier Weathermaker 9200 Chipley HVAC 12 12-16-2008 12:44 PM
