-   -   Carrier weathermaker 9200 (http://www.diychatroom.com/f17/carrier-weathermaker-9200-a-88847/)
jnspence 12-06-2010 12:11 PM
Hi, I have a carrier weathermaker 9200 58MXA040. I disconnected the control board to get access into the back area to replace the collector box drain tube. I am now unsure where a wire I took off goes back on the control board. It is the main electrical supply wire (black). It comes from the where the main electical cord goes into the unit. There is a white wire that runs next to it. If anyone has knowledge of these systems I would really appreciate it. I can describe it in more detail if needed as well. Thanks
hvaclover 12-06-2010 01:12 PM
look at the wireing diagram. where it says L1 and L2 on the diagram it will have corresponding marking. black goes to L1.
jnspence 12-06-2010 01:28 PM
Thanks hvaclover. I am at work but will look at it when I get home. I think you nailed tho. I will post back with an update.
jnspence 12-07-2010 11:37 AM
HVAClover you are the man. Thanks again. The diagram makes complete sense now. Next time I will take better notes when removing so many wires.
