Carrier Weathermaker 8000 Help Please - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 05:23 PM   #1
Carrier Weathermaker 8000 help please
I've got a Carrier Weathermaker 8000 that began blowing cold today and I've been researching the problem online. It's throwing a code 33 and I want to try to manually reset the flame roll-out switch but I cannot for the life of me find it.
Also, I had it turned on and off several times and each time the blower would come on and nothing else would happen. I decided to try to clean the flame sensor and when I re-installed it and turned the furnace back on the igniter glowed this time and the small blower by the upper plenum kicked on but, I never got a flame. It shut down and when it cycled again only the main blower started blowing again.
TenTwelve is offline   Reply With Quote
Old 01-11-2010, 05:43 PM   #2
Carrier circuit boards turn the blower on when the power is interupted and there's a call for heat.
Got a meter to check if there's 24 volts going to the gas valve after the ignitor glows?
Old 01-11-2010, 05:49 PM   #3
Unfortunately no, I have no way to check that.
Carrier 8000 TS - code 24 ? jumpball HVAC 6 03-22-2014 11:39 AM
Carrier Weather Make 8000 58DLA Problem hobbsje HVAC 6 12-29-2009 10:41 PM
Carrier Weathermaker 8000, Gas Furnace Problem kiss44 HVAC 1 10-18-2009 08:27 AM
Carrier Weathermaker SX - Weak Air Movement eAndy HVAC 4 09-12-2008 09:29 PM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 02:27 PM
