Carrier Weathermaker 8000 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 06:40 PM   #1
Good Afternoon,
I have a Carrier Weathermaker 8000 that has a heating issue. I had a technician look at it and after much testing he handed me the bad part. It was a Tridelta pressure switch. I purchased it and have installed it myself as there wasn't much too the part. Now, the problem is that the technician did not reattach a white wire(neutral) to the control board. This white wire is coming directly out of the electrical box inside the cabinet and it seems to go to a tab on the control board marked L2. The control board is a replacement to the original and it is labeled ICM 282. I have already hooked up the wire and plugged in the unit. I see there is a solid red LED light on the control board, but heard a hum coming from the unit, so I unplugged it.
Can anybody confirm that the L2 tab is the correct tab, or suggest the correct tab?
Thank you in advance.
282flip is offline   Reply With Quote
Old 01-05-2013, 06:44 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
L2 is correct,
L1 or line 1 is Hot and L2 is neutral. Black is always Hot and White neutral.
The humming is normal and is the transformer. The Red LED is a good sign and means the power is on.
No worries.
The Following User Says Thank You to yuri For This Useful Post:
282flip (01-05-2013)
Old 01-05-2013, 07:10 PM   #3
Rewards Points: 616
why would you not have the tec put a new one in.... he was allready there....
carmon is offline   Reply With Quote
Old 01-05-2013, 07:28 PM   #4
Hi Carmon,
The technician had to order the part and it would take a week to come in. He said it would $350.00 to install it. I purchased one on ebay for 11.00. It only had two wires and one hose to connect, it looked like an easy repair to do myself.
Old 01-05-2013, 07:34 PM   #5
Rewards Points: 616
oh my goodness.... I sure don't blame you..... hope all went well....
The Following User Says Thank You to carmon For This Useful Post:
Tags
carrier weathermaker 8000 , icm 282 control board , led light
Carrier Weathermaker 8000 startup probs muldercs HVAC 13 11-19-2012 05:28 PM
Carrier weathermaker 8000 - polarity issue? mviker HVAC 5 11-02-2012 10:08 AM
Carrier Weathermaker 8000 not lighting-please help! karyn HVAC 10 10-31-2012 06:20 PM
Carrier Weathermaker 8000 thermostat out, air blowing Saveme$ HVAC 30 01-08-2012 10:42 PM
Carrier Weathermaker 8000 help please TenTwelve HVAC 2 01-11-2010 05:49 PM
