Carrier Weathermaker?? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 01:17 PM   #1
carrier weathermaker??
I have an older Weathermaker just for heat bought it with a fried board so I installed a new ugraded to ICM 275...now when I start the furnace it starts fine... pilot lights but when the main burner is suppose to start the inline sec-1 2 amp fuse blows everytime and the furnace shuts off??? Any ideas?
eric1192 is offline   Reply With Quote
Old 12-02-2008, 03:23 PM   #2
Short in the system. The furnace blew the old board because of it.
You may have a White Elephant on your hands.
hvaclover is offline   Reply With Quote
Old 12-02-2008, 05:22 PM   #3
I also just found out the pilot ignition keep firing until the fuse blows??
Old 12-02-2008, 05:38 PM   #4
Unless you have a meter and know how to use it, it will be hard to tell what's up.
Is this a 80% or 90% furnace?
Old 12-02-2008, 05:45 PM   #5
Not sure on the %... I do have a meter, tried manually so start the main burner with a jumper and the fuse blew, I took apart the pilot assembly to see If it was dirty and and looked pretty clean the sensor was a little tarnished but aside of that it was all good, I'm getting a nice blue flame!
Old 12-02-2008, 05:57 PM   #6
biggles's Avatar
what size is that fuse..........sec-1 2? if it is a 2 amp the draw from the main burner coming on might be knocking it out not shorting it.if you put a amprobe on the fuse line and see a spike thats a short.might just need a higher rating same type to fit holder.
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 06:30 PM
Carrier Weathermaker SX Problem hchampagne HVAC 2 09-23-2008 09:48 PM
Carrier Weathermaker SX - Weak Air Movement eAndy HVAC 4 09-12-2008 09:29 PM
Carrier Weathermaker SX Exhaust Fan Motor rickvj HVAC 6 01-22-2008 10:45 PM
Carrier code 31 on 58MXA (WeatherMaker 9000?) SteveAnnArbor HVAC 7 11-05-2007 06:53 PM
