Carrier Weathermaker - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2012, 06:27 AM   #1
carrier weathermaker
My carrierwaethermaker is failing to ignite, I can shut down the power then turn it back on, but it is still taking 2 or 3 cycles to light. The igniter was replaced last winter.
mctyedye is offline   Reply With Quote
Old 02-06-2012, 02:28 PM   #2
HVAC Tech/ Browns Fan
Are you hearing the gas valve opening when the glow plug is not coming on?
Tator1076 is offline   Reply With Quote
Old 02-06-2012, 03:12 PM   #3
how
Rewards Points: 1,104
Is the glow plug lighting up every time that you are not getting ignition?
Are you hearing a clicking sound in the gas valve everytime it tries to fire up?
Does it just briefly fire and then immediately shut off to cycle again?
Do you have a blinking led light in the furnace that is giving you a diagnostic when the unit doesn't fire up?
how is offline   Reply With Quote
Carrier Weathermaker 8000 thermostat out, air blowing Saveme$ HVAC 30 01-08-2012 10:42 PM
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 07:04 PM
Carrier Weathermaker 9200 klrz28 HVAC 24 04-23-2011 07:37 PM
Carrier weathermaker 9200 jnspence HVAC 3 12-07-2010 11:37 AM
Carrier Weathermaker SX mikeschu HVAC 1 11-01-2010 04:13 AM
