Carrier Weather Maker Inducer Voltages - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 07:46 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 396
Use2B , I have always replaced the entire ventor assembly as mine were under warranty. Guess you will have to let Us know how to do it.
Good Luck
Old 10-16-2009, 02:43 AM   #17
OK, it wasn't easy. After removing the inducer assembly, I had to remove a set screw that attached the fan blades to the motor shaft. The only way to access it was to open the inducer assembly. However, the plastic blades have a steel center which was frozen on the motor shaft. Long story short, I had to drill the motor shaft completely out and collapse even the thin piece remaining. In the process, it would have been very easy to damage the plastic blades or break them free from the steel center. I was able to reassemble the inducer assembly with the new motor and reinstall it in the furnace. Everything worked fine on the startup test using dip switch 6. I closed up the furnace and it is working well. For most people faced with this problem, I would recommend getting the full inducer assembly and motor combination. However, I was able to save over $200 by only replacing the motor itself.
used2beatech is offline   Reply With Quote
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 06:43 PM
Carrier Model 58MVP inducer motor deanray HVAC 11 11-19-2010 04:33 PM
Carrier weather maker 9200 furnace NO 24 volts mmtuxedo HVAC 1 09-25-2009 06:49 PM
Carrier Draft Inducer Problem? ChiTown HVAC 5 12-24-2008 07:16 AM
Carrier Weather Maker not turning on rickvj HVAC 5 10-25-2007 12:46 PM
