-   -   Carrier Weather Maker inducer voltages (http://www.diychatroom.com/f17/carrier-weather-maker-inducer-voltages-54834/)
used2beatech 10-10-2009 11:26 AM
I have a Carrier Weather Maker furnace and the LED code is reading 42. This means the inducer is not up to the proper RPM. Actually the inducer isn't turning at all or even making an attempt. I am trying to determine if the motor or the controller is the problem. I went through the start up process by switching dip switch 6 to the on position and had the same result. I have 120VAC to the motor and I need to check the other voltages to see if the controller is providing the signal. The wiring diagram on the heater doesn't show voltages. Where can I find the voltages (probably 24V) for the yellow, orange, and brown wires?
Plumber101 10-10-2009 12:27 PM
With the motor disconnected use a DVOM and probe into the motor leads.
Check ohms and for continuity. This will tell you if the motor is bad.
Post results
yuri 10-10-2009 01:29 PM
B4 you go poking around in there turn off the power and wait 5 mins. There are 3 LARGE capacitors in the module and they can kill you if they are not allowed to discharge slowly.
used2beatech 10-10-2009 07:40 PM
Plumber101, thank you for the reminder about checking the ohms & continuity.
Yuri, thanks for letting me know about the capacitors. Are the capacitors in the control module or with the ECM motor? After waiting 5 minutes, should I short them with a screwdriver just to be sure the charge is depleted?
yuri 10-10-2009 08:04 PM
They are in the module and will drain themselves. Probably have a bleed resistor circuit on them. They are BIG and powerful suckers. A capacitor can explode if discharged with a screwdriver. I would wait 10 minutes to be safe. Here is a troubleshooting manual for U:http://www.hvactroubleshooters.com/C...20FURNACES.pdf
Depending on which version of the motor you have the best way is to use a Teckmate simulator to test the motor:http://www.thedealertoolbox.com/service.php
There is very good info on ECM motors at that site.
Good Luck
used2beatech 10-10-2009 09:31 PM
Yuri, You're Awesome! I appreciate the links. I'll follow these procedures and hopefully determine the actual cause of the problem. I'll keep you posted.
Plumber101 10-10-2009 09:52 PM
Good Luck
Yuri,
I thought he was trouble shooting an inducer motor and not a VS blower motor. I didn't think the teckmate was for inducer motors. If you could explain to me so if there is something I'm missing I will be better for my next service call
used2beatech 10-10-2009 10:16 PM
Yuri, based on my earlier inspection, I used Appendix D Quick Motor Test Procedure. The voltages on the inducer connection (step 18) checked out nicely at 0, 2.48, & 7.46vdc. The next step is to replace the inducer motor or motor assembly. Now, I just have to find a motor at a good price.
Plumber101 10-10-2009 10:18 PM
Guess I need to read a little more
yuri 10-11-2009 09:23 AM
Yah, I missed the inducer too. Only Carrier uses ECM inducers that I know of. (The new Lennox G71 now has one). That furnace is a Bear to troubleshoot. Carrier threw every bit of technology they could think of into it. Overkill IMO.
The inducer and fan is one complete unit and has to be purchased as one. Difficult to replace and let me know when you are doing it and I will talk you thru it/save you a LOT of misery.
used2beatech 10-14-2009 06:32 PM
Hi Yuri,
I received a new ECM motor. I was able to get just the motor without the complete assembly. I have unsrewed the motor mount but I can't figure out how to remove the old motor (pull it away from the inducer). I can see on the new motor that the shaft has a flat portion at the end (a key) and it is smooth so I confident it doesn't have a C ring on the end. It should simply pull out. When I pull on the old motor it offers resistance. I don't want to break anything. Do you have any suggestions?
Thanks,
Michael
hvaclover 10-14-2009 06:48 PM
LOL...got it caught in your zipper, ey buddy?:laughing:
I had me a dozy on another site. Still too embarrassed to show my face at that site.
Plumber101 10-14-2009 06:52 PM
And biy did it bleed..every thing here fine just a bunch of service calls. No one in my area likes to work on fireplace NG/LPG inserts. Can you say $$$$
Yesterday 7 furnaces and 3 fire place, today new install and tomorrow new install just freak'n busy
and
You?
hvaclover 10-14-2009 06:57 PM
One annual inspection yesterday---ALL DAY.
We work on the low volume high profit program:yes:
Got two installs lined up but I can't do them cause of my back. So i got me a new guy.
Plumber101 10-14-2009 07:00 PM
How do I get on that progam..
But then again maybe I'm on the High volume High profit program..I won't say which one I'm on:thumbup:
