Old 01-12-2013, 12:30 PM   #1
carrier weather maker 9200 furnace
My furnace is dead.Got up no heat,checked furnace no led light flashing no power no nothing.Checked breaker,checked fuses on furnace all checked out good.What should I do ,use a sledge hammer on it?Would appreciate what ever you can help me with.Got a cold front moving in for monday,need to fix it bad.Thanks
papa5 is offline   Reply With Quote
Old 01-12-2013, 12:59 PM   #2
Hvac Pro
Get a voltage tester and check if there is power after the breaker or fuse and check for power at the furnace disconnect switch which may be at the furnace or on the ceiling or wall in the furnace room or stairwell to the furnace or call a electrician or furnace tech if this is beyond your ability.
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 09:48 PM
Gas Furnace Hiccups hugocraft HVAC 2 12-22-2012 07:50 AM
Carrier Furnace Burners Cycling On/Off diyguy777 HVAC 3 10-15-2012 07:23 PM
Weather Maker 9200 Furnace benoy HVAC 5 12-07-2009 09:03 PM
Carrier 58MCA Furnace – No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 08:32 PM
