-   -   carrier weather maker 9200 furnace (http://www.diychatroom.com/f17/carrier-weather-maker-9200-furnace-168907/)
papa5 01-12-2013 12:30 PM
My furnace is dead.Got up no heat,checked furnace no led light flashing no power no nothing.Checked breaker,checked fuses on furnace all checked out good.What should I do ,use a sledge hammer on it?Would appreciate what ever you can help me with.Got a cold front moving in for monday,need to fix it bad.Thanks
yuri 01-12-2013 12:59 PM
Get a voltage tester and check if there is power after the breaker or fuse and check for power at the furnace disconnect switch which may be at the furnace or on the ceiling or wall in the furnace room or stairwell to the furnace or call a electrician or furnace tech if this is beyond your ability.
