Carrier Weather Maker 9200 Can't Start - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 09:06 PM   #1
Carrier weather Maker 9200 can't start
The ignitor turns red, but it fails to start if I leave the front cover fully on. it will start if I remove the cover or leave enough space to let pressure out. what's wrong with it?
yzhu is offline   Reply With Quote
Old 01-04-2013, 10:38 PM   #2
Rewards Points: 616
sounds like pressure switch not making
carmon is offline   Reply With Quote
Old 01-05-2013, 10:21 AM   #3
An old Tradesmen
Rewards Points: 6,500
Is it a condensing furnace? Could be a problem with the secondary.
Old 01-05-2013, 10:31 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
9200 is a 92% high. check venting for obstructions.
Old 01-05-2013, 02:17 PM   #5
Rewards Points: 196
check intake pipe where it goes into the black combustion air connector.There is usually a white disk that catches leaves.
HVACTECH96 is offline   Reply With Quote
Carrier Weathermaker 9200 - Blower not turning on. bvijay HVAC 7 08-15-2011 08:04 PM
Carrier 9200 3 amp fuse furnacehelpreq HVAC 1 07-27-2010 03:57 PM
Seasonal maintenance on Carrier 9200 gshock HVAC 4 04-12-2009 10:19 PM
Carrier Weathermaker 9200 58MXA080-16 Cosmo HVAC 7 03-09-2009 04:15 PM
Carrier 9200 Code 34 fault cu1982 HVAC 8 01-02-2009 09:56 PM
