Carrier Weather Maker 9200 - HVAC - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 05:37 PM   #1
Carrier weather maker 9200
Having a problem keeping the heater on. light blinks showing a vent problem. checked the vent and it was ok. unplugged the elec. and to let it reset which I had to do several times and it would come on and heat but not for long but some times days and then it would shut down and blink a vent problem again. Can someone give me an idea on what to check next? this unit has been in the same house for 10 years. Thanks
wjkrostek is offline   Reply With Quote
Old 05-28-2012, 07:01 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
It could be a heat exchanger issue. Call a pro.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-28-2012, 09:52 PM   #3
Rewards Points: 582
for sure call in a pro on this one as mentioned it could have a cracked heat exchanger...don't take a chance...
Old 05-28-2012, 11:41 PM   #4
how
Rewards Points: 1,102
I would check that all the pressure lines are in good shape, no split ends or holes.
Make sure none of them are filled with water.
Make sure that there isn't a build up of crud just inside the vent motor assy where the pressure line attaches to it. Try a staightened paper clip to test or clear it out.
Make sure that the electrical connections are secure on all the pressure switches.
In addition to a possible exchanger failure, other common causes could be a failing vent motor, pressure switch or a partial vent line obstruction.
Let us know what you find.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (05-29-2012)
carrier weather maker 9200 leak craiglalonde HVAC 5 12-12-2010 11:39 PM
Weather Maker 9200 Furnace benoy HVAC 5 12-07-2009 09:03 PM
Carrier Weather Maker inducer voltages used2beatech HVAC 16 10-16-2009 03:43 AM
Carrier weather maker 9200 furnace NO 24 volts mmtuxedo HVAC 1 09-25-2009 07:49 PM
Carrier Weather Maker not turning on rickvj HVAC 5 10-25-2007 01:46 PM
