-   -   Carrier weather maker 9200 (http://www.diychatroom.com/f17/carrier-weather-maker-9200-a-145151/)
wjkrostek 05-28-2012 05:37 PM
Having a problem keeping the heater on. light blinks showing a vent problem. checked the vent and it was ok. unplugged the elec. and to let it reset which I had to do several times and it would come on and heat but not for long but some times days and then it would shut down and blink a vent problem again. Can someone give me an idea on what to check next? this unit has been in the same house for 10 years. Thanks
hvactech126 05-28-2012 07:01 PM
It could be a heat exchanger issue. Call a pro.
ben's plumbing 05-28-2012 09:52 PM
for sure call in a pro on this one as mentioned it could have a cracked heat exchanger...don't take a chance...:yes:
how 05-28-2012 11:41 PM
I would check that all the pressure lines are in good shape, no split ends or holes.
Make sure none of them are filled with water.
Make sure that there isn't a build up of crud just inside the vent motor assy where the pressure line attaches to it. Try a staightened paper clip to test or clear it out.
Make sure that the electrical connections are secure on all the pressure switches.
In addition to a possible exchanger failure, other common causes could be a failing vent motor, pressure switch or a partial vent line obstruction.
Let us know what you find.
