Carrier Weather Maker 8000 Lights Inconsistantly - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 12:07 PM   #1
I am having a problem with my Carrier WeatherMaker 8000. It is about 18 years old. Recently it began having an intermittent problem. We wake up in the morning and the house would be 60 degrees when the thermostat is set for 65. The digital thermostat shows it is calling for heat but the furnace is not responding. I took the covers off the unit and watched and timed the startup cycle to see if I could see what was going on.
This is what I observed.
The main blower motor would come on for 90 seconds. At 90 seconds the main blower turns off and the inducer (I hope the at is the right term) kicks on and blows for about 25 seconds and then the ignitor begins to glow. About 8 seconds later I hear a click which I assume is the signal for the gas flow to begin. However, the flames never start and I do not really smell any gas flowing. After a short time the ignitor stops glowing. Several seconds later the ignitor starts to glow again but no flames some on and the ignitor stops glowing.
If I leave the furnace turned down to a low heat setting for awhile, say an hour, then turn up the thermostat the furnace works normally. The burners turn on when they should and the furnace works for a couple of days or a week and then the problem returns. I have changed the filter. I usually change it monthly. The interval between problems seems to be growing shorter. Any advise would be greatly appreciated.
reockey is offline   Reply With Quote
Old 02-04-2012, 01:03 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
put a volt meter across the 2 wires to the gas valve, should read 24 volts AC. at the same time check any other gas appliances that U have to see if they are working. 95% chance the gas valve is sticking closed due to old age. 5% chance your gas meter or regulator is failing BUT only if the other appliances are not working properly too.
Old 02-04-2012, 02:01 PM   #3
Thanks for your refply Yuri. I will try that. If it appears to be the valve should I have a professional replace it? I assume that if I am not experienced in working with gas lines that I should not attempt it myself. Would you agree?
Old 02-04-2012, 02:44 PM   #4
yes......yuri and any other pro.......would agree.
harleyrider is offline   Reply With Quote
Old 02-04-2012, 03:24 PM   #5
Hvac Pro
yuri's Avatar
Yes. A Pro is needed.
Old 02-04-2012, 08:40 PM   #6
Rewards Points: 582
for sure if its any thing to do with gas that is not a diy project....
Tags
carrier 8000 , inconsistant ignition
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Day & Night (Carrier) Natural Gas Furnace Lights Sometimes scotth1981 HVAC 6 11-03-2011 05:14 PM
Carrier furnace problem. Pilot lights, no burner Donut HVAC 1 02-09-2011 08:07 PM
Weather Maker 8000 2 Spd Problem hodgeviper HVAC 4 12-31-2009 03:57 PM
