Carrier WatherMaker 8000TS Not Working Now - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 04:29 PM   #1
Rewards Points: 29
Lightbulb
Carrier WatherMaker 8000TS not working now
Just happened this morning, first hear noise from induced, then stopped, now only blower works, and not ignite, the circuit board LED flash 3 times and goes to circle. a technician cames said need replace circuit board, not sure it, it looks trouble from induced? any ideas about this, thanks
Ballastar is offline   Reply With Quote
Old 02-17-2010, 05:12 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
It should flash a 2 digit code, with short and long flashes which you read on the legend on the furnace door. Check again and count the flashes and read the legend CAREFULLY. May be slightly different as yours is a 2 stage furnace.
Old 02-17-2010, 05:46 PM   #3
Rewards Points: 29
Yes, it's a 2 stage furnace, and flash 2 shorts + 1 long, each circle
Old 02-17-2010, 05:53 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
Read your legend, mine is from a 1 stage unit and may be different. What is code 21 on your legend?
Old 02-17-2010, 09:21 PM   #5
Rewards Points: 29
Thank you for reply, I did not see any LED code legend on my furncae door back, even the manual, so if code 12 or 21, how can I do?!
Carrier Heat Pump stopped working burnselk HVAC 2 02-06-2010 12:30 AM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 06:30 PM
Carrier 58MSA - Working Intermittently Johnpcf HVAC 6 12-23-2008 09:13 PM
Carrier 8000TS Control Bd Fuse blows EAP HVAC 2 08-28-2008 08:07 PM
