Carrier Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 09:32 PM   #1
Carrier Unit
I have a Carrier ac/gas heater model #48ss-036080301. We turn the heat on but it wont stay running. We have to flip the circit breaker to get it to turn back on, but it run for a little bit then it will not turn back on. Is this the igniter that i can replace or should i call a expert? Thanks Joe in NC
Joe Ivkovich is offline   Reply With Quote
Old 11-07-2010, 10:23 PM   #2
HVAC / Plumbing
Probably not the ignitor. PS not staying closed, flame sensor,cycling off on limit, etc,.
kenmac is offline   Reply With Quote
Old 11-05-2013, 12:57 PM   #3
We have a WeatherMaker 9200 unit with similar issues. It won't run when the temp dips below the preset temp (for heating). When I turn the unit off, then on, it runs briefly but then stops. When I turn on the fan, it runs until I shut it off.
The unit does NOT trip the circuit breaker. I have changed the filter.
Any suggestions?
Frump is offline   Reply With Quote
Old 11-05-2013, 01:46 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
remove the front door and look at the bottom door and there is a viewing window. inside you will see a flashing LED. CAREFULLY count the long and short flashes as they can look the same for newbies. then find the code on the sticker which is on the door or back of it and report back. DO NOT reset the power B4 doing that as it erases the code.
Old 11-05-2013, 03:46 PM   #5
Thanks. It appears to be 4 long lights and one short. I am guessing that is #14 on the door = Ignition Lock Out. Any advice on restarting this?
Old 11-05-2013, 04:29 PM   #6
Hvac Pro
yuri's Avatar
read the sticker as code 14 becomes code 34. when you said it runs briefly, how long is that. 30 seconds, 1 minute? normally the exhaust fan starts and runs 1-2 minutes and then there is a red glow inside the burner box ( look in the window ) of the igniter. let us know if you see the red glow. if not there could be a variety of problems and you need to have an electrical meter and know how to use it for us to help or call a Pro if you don't.
Old 11-05-2013, 05:02 PM   #7
Thanks -- I'll look for the red glow. However, the unit stays on for about 3 minutes. Be right back.
Old 11-05-2013, 05:11 PM   #8
OK, I am back. I noticed something additional when turning off, then on, the power switch to the unit.
1.) The red light does "glow" in one of the two round windows, but begins to flash as 4-long, 3-short flashes. This cycles for about 3 minutes.
2.) After "1" above, the unit shuts down, and the flashing light sequence changes to 1-short, 4-long flashes.
I did not see any other red glowing or other glowing in either of the two small, round windows on the bottom nor any glowing (any lights for that matter) in the small round window found at the top of this compartment of the unit.
Thoughts on that?
Old 11-05-2013, 05:18 PM   #9
Hvac Pro
yuri's Avatar
you count the short and then the long to get the code and it is correct. you are getting no ignition because the gas valve is not opening due to a bad valve or circuit board and then it locks out and goes to code 14. do you have a gas water heater or stove or fireplace and is it working? if not call the gas co as your meter may be faulty. go outside and make sure no one turned it off.
Old 11-05-2013, 05:26 PM   #10
OK, seems we are narrowing down the problem. We have gas heat in the house as well as for cooking -- all are running fine except the upstairs unit (we have a 2-tier system -- bottom system works fine).
Old 11-05-2013, 05:32 PM   #11
Hvac Pro
yuri's Avatar
while the igniter is glowing you need to have 24 volts AC across the 2 wires of the gas valve. if none then the circuit board may be bad. if you have 24 volts and no gas flow then the valve is bad and that is rare. or the burners are dirty and you need a Pro to clean and set them properly.
Old 11-05-2013, 06:44 PM   #12
OK, thank you very much -- I already have a call in for service. Again, thanks for your feedback -- quite helpful.
Old 11-05-2013, 06:50 PM   #13
Hvac Pro
yuri's Avatar
Good Luck, at least you have an idea what is going on before they get there.
there is also a possibility the igniter is getting weak, if it does not glow bright red enough it won't lite the gas as the color relates to an ignition temperature.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 06:13 AM
Wiring Honeywell thermostat to Carrier Unit Captk1959 HVAC 1 03-26-2010 11:26 AM
Carrier 48GS unit turns on, but no heat coldlady HVAC 0 10-30-2009 09:30 PM
carrier unit heatcker61 HVAC 1 06-01-2009 04:46 PM
Carrier Unit not cycling properly kentk1 HVAC 20 01-12-2009 04:06 PM
