Carrier UNIT - HVAC - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 04:40 PM   #1
Smile
Carrier UNIT
This past winter, my heat pump would only run off of emergency heat. When summer came the AC worked good. It was a couple of weeks that we didn't use the ac or heat. However, Now the outside unit will not come on. My husband kick started by holding a contact button it, but the compresor ran for a minute than made a hiss noise, I am affraid of him trying to over ride the unit like that. Any Ideal what this may be? AC was working great so i have no clue. The fan in the squarl cage is coming on, but than it will click off. If you move the thermostat around it will come on than click off. the fan on top will not even come on
dcoleman is offline   Reply With Quote
Old 05-29-2011, 05:12 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Fan on top of the heat pump is or is not running while on call for cool and heat?
Doc Holliday is offline   Reply With Quote
Old 05-29-2011, 05:17 PM   #3
It will not run, Unless he pushes this contact button in the service are of the ac. Than it will come on and stay on while he holds that button in
Old 05-29-2011, 05:20 PM   #4
An old Tradesmen
Rewards Points: 6,074
Could be a wiring problem, or a SAFETY doing its job.
Old 05-29-2011, 05:28 PM   #5
does that mean its out of freone? All wires look good. Does it take freone for the heat pump to work also? Thank you so much for your time
Old 05-29-2011, 05:34 PM   #6
An old Tradesmen
It could be out or low. And yes, it needs its refrigerant charge(freon) to work in heat mode.
Continuing to hold in the contactor and making the compressor run with a low charge can do harm to the compressor, and cost lots more to repair.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Wiring Honeywell thermostat to Carrier Unit Captk1959 HVAC 1 03-26-2010 11:26 AM
Replacing inside air control unit - have to replace outside as well? yalej HVAC 2 04-29-2009 12:46 PM
Electric question from power pole to unit Slocalaman Electrical 3 11-06-2008 04:23 PM
Home Outside A/C Unit Won't Power Up ldeneale HVAC 3 10-29-2008 05:37 PM
