Carrier Thermostat Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 03:42 PM   #1
My parents currently have a mercury thermostat (Carrier T864R1384) that they want to replace. What would be the model of choice for them if they were looking for the easiest to install? Thanks, any guidance would be greatly appreciated!
smith1234 is offline   Reply With Quote
Old 11-14-2011, 05:13 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,140
T86R sounds like a specialty tstat. Do they live in a condo or have hot water heat? Need to know what type of heating system they have and how many wires the tstat has. Post make/model and serial # if you can.
Old 11-14-2011, 06:08 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
$30-ish dollars and very simple to install. Very basic non programmable single stage digital stat. You can get a programmable version for roughly $5-$10 more, same brand.
Cheap but they work.
Doc Holliday is offline   Reply With Quote
Carrier Infinity and Thermostat Replacement upsidedown HVAC 1 10-11-2011 01:55 PM
E2 code on Carrier OMTSTAT_3 thermostat strikeeagle HVAC 13 05-15-2011 02:42 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
