Carrier Squeals - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 12:24 PM   #1
Newbie Bill
Rewards Points: 518
Carrier squeals
Hey guys,
Over the last few months, we often hear a sqeal from our Carrier High efficiency 2 stage furnace as the blower drops out of high to low speed. It is short in duration and WAS only heard with the change in fan speed. No squeals or squeeks while fan is running. Then the other evening, I heard it as the blower went from low speed to high (it was a very short squeal).
I did a search here and learned it may be the blower fan is a bit loose and it moves as the fan speed changes.
And a few threads point to bearings on the blower motor starting to go.
Any thoughts?
I'm hoping it an easy fix as I don't want to have to replace the blower. The furnace is only 6 years old and of course, warranty ended at 5.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-14-2013, 12:51 PM   #2
Rewards Points: 12,802
Belt driven?
Change the belt and make sure every turns freely when it's off.
Old 01-14-2013, 01:07 PM   #3
Newbie Bill
Rewards Points: 518
I didn't know the fans in these newer furnaces were still belt driven? I'd definitely prefer the cost to fix that than having to replace the entire motor.
I'll check into that in the next day or so.
Bill
Old 01-14-2013, 03:38 PM   #4
Roofmaster
Rewards Points: 2,172
Ill bet the set screw came loose on squirrel cage to the motor shaft.
Easy fix. Pull the Blower out off its rails, Take the motor off the blower
housing. remove the blower cage and clean it rel good. If you have a laundry sink, fill it up add TSP a little bleach and dish soap and let it set to loosen the crap in the buckets. Wire brush the buckets with a small wire brush.
Put Blower set screw back with blue Loc-Tite
Old 01-15-2013, 10:37 AM   #5
Newbie Bill
Rewards Points: 518
Sounds easy enough but I'm thinking I'll have the HVAC guy check this. I'm scared I won't be able to get it back together and we'd be without heat for a day or two.
Bill
Old 01-15-2013, 01:53 PM   #6
Rewards Points: 446
That was in the fine print disclaimer that came with his instructions.
old_squid is offline   Reply With Quote
Old 01-23-2013, 03:41 PM   #7
Newbie Bill
Rewards Points: 518
Seems like it may have been a loose screw. Seems ggod now immediately after tightening so let's hope that was the problem.
Thanks for everyone's input.
Bill
Humidifier for Carrier Infinity 96 system rvmeush HVAC 1 09-19-2012 07:16 AM
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
