Carrier - ?s On Night Time Shut Downs - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2008, 09:49 PM   #1
Carrier - ?s on Night time shut downs
I work on Carrier/Bryant furnaces for a property. Their model # starts 394GAZ.
I have furnaces that are shuting down over night. Working during the day. Possibly after a reset. Sometimes I have certain devices replaced. Like - 3wire pilot, Ignition module, and circuit board. In one instance, I have replaced the gas valve.
But then I have an overnight shutdown on a resident. What is the culprit to this?
Any help is appreciated?
wilgo5234 is offline   Reply With Quote
Old 02-19-2008, 04:58 AM   #2
biggles's Avatar
the night problem could be thru the stat,if it has multiple settings forrsay after 9PM it looks at a 50F setting.if your running a round honeywell with heat only no setbacks to touch then it is just maint.
Old 02-19-2008, 07:54 AM   #3
Analog mercury switch for thermostat.
Temp set at a constant
Carrier Furnace: Gas Heating Lockout kkf HVAC 20 02-17-2017 05:55 PM
Carrier furnace fan wouldn't shut off claymthomas HVAC 5 01-21-2008 06:39 AM
Bloody anoying night time bird chirping grrr fridgeman Pest Control 6 11-08-2007 11:30 PM
