Carrier Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-03-2007, 06:16 PM   #16
HvacWiz's Avatar
Rewards Points: 252
Only thing I can think of to tell you at this point is to measure the voltage across the presure switch terminals on the call for heat, if you have no voltage that means your switch is closed and working properly, if you show 24v that tells you the switch is not closing on call for heat.
HvacWiz is offline   Reply With Quote
Old 12-03-2007, 08:15 PM   #17
so if it reads 24v then i need to get a new switch?
cullens089 is offline   Reply With Quote
Old 12-03-2007, 08:30 PM   #18
HvacWiz's Avatar
Rewards Points: 252
Yes, if you have made sure everything else is ok that we have talked about. Good luck
Old 12-03-2007, 08:40 PM   #19
ok where would the switch be located?
Carrier 58MVP Blower Problem mickd HVAC 57 04-11-2017 07:28 AM
carrier furnace problem dqdave1 HVAC 14 02-06-2010 04:57 PM
another Carrier furnace problem jhrodd HVAC 5 02-18-2007 12:09 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 09:18 PM
