Old 11-02-2009, 07:18 PM   #1
Default Carrier pressure switch test
A furnace technician recently checked my furnace. He pulled the tube off the pressure safety switch and told me the fan motor should stop. I then replaced the switch and tried it again. Same thing. I called him and he said "no, I said the flame should go out". So I pulled the tube and watched the flame for 30 seconds and it did not go out. Which is correct and do I still have a problem, ie what should occur if you remove the pressure from that switch. Thanx in advance.
spider18 is offline   Reply With Quote
Old 11-02-2009, 08:18 PM   #2
old pro
Depends if it has 2 hoses to it or 1. If one then it should shut off the burner. Post the model # here. Is it a high efficiency unit with plastic venting pipes or one with a metal pipe to the chimney? A picture of the furnace and switch will help also.
Old 11-03-2009, 06:51 AM   #3
An old Tradesmen
Yep. If its a 2 hose switch. If you pull the wrong hose, it can stay running(or is that the right hose).
If the switch is bad, the furnace shouldn't make it to the ignition cycle.
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Hi my name is Tim Ambrosuis and I am a professional guitar technician for Expert Village.com. I am going to show you how to change a preamp tube on a tube amplifier. On this one we are going to have a back plate that you are going to need to take off to... Read More »
Hi I'm Ed Story on behalf of expertvillage.com. My website is www.feather-craft.com fly fishing. Here I'm going to tie a marabou streamer from a marabou streamer kit on our website and I'm preparing the thread now from pulling it away from its little... Read More »
Just for fun Andy in ATL Electrical 56 10-20-2009 11:33 AM
furnace pressure switch Mike T. HVAC 3 10-10-2009 03:26 PM
4 way switch confusion Richo Electrical 10 04-09-2009 09:11 AM
Trane Carrier XL80 fan runs constantly when switch is on jheavner HVAC 13 10-25-2008 11:54 PM
Bad pressure switch? gshock HVAC 3 11-13-2007 09:15 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
