Carrier/ Payne FAU Gas Lockout, Codes 31, 33 And 13 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 10:09 PM   #1
Carrier/ Payne FAU Gas lockout, codes 31, 33 and 13
I have an older, (emphasize older) FAU unit that has issues every winter when I start it up after it sits over the summer. I have replaced many parts and just replaced the control board. Symptoms: blower starts, 90 seconds, then goes off. inducer fan did come on, but now won't. Am getting a 31 code now, but have gotten 33 and 13. I have checked for blockages and the list under code 31, but am becoming frustrated. Right after replacing the control board, it fired right up and worked for hours, then I turned down the thermostat for the night and now it won't come back on. I checked the reset buttons & the vacume switch, nothing tripped I could find and Vswitch seems to be working. Now I don't know what to do. Seems like there's a gas lockout. Because it's so old, should I check the heat exchanger cell for carbon, etc & possibly clean it? Maybe the limit switch is bad? Thanks
jeannem is offline   Reply With Quote
Old 11-10-2011, 06:56 AM   #2
jkv
Jump the stat and see if it will come on if it dont then you may just need a new stat. The pannel should tell you what the codes are and check the tube on the inducer motor for any breaks or cracks.
jkv is offline   Reply With Quote
Old 11-10-2011, 07:11 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
It woud appear that the pressure switch is not "working" if the inducer is not coming on, right? Right.
Carrier boards recognize when power has been cut to the unit, thus comes code 12 and the blower running for 90 seconds first before the heat cycle.
Reset the power to the unit, turn the breaker off for a few seconds. See if it fires back up. Again, it will run the blower first for 90 seconds then go into heat by way if inducer.
Doc Holliday is offline   Reply With Quote
Carrier error codes 48ss package jadams43 HVAC 0 01-24-2011 08:03 PM
What are the carrier furnace codes? porang HVAC 1 01-24-2011 07:45 PM
Lockout on Carrier 58mxb adam2blpc HVAC 4 01-11-2011 10:44 AM
Carrier Weathermaker SXi Codes 41 and 44 Knight78 HVAC 5 11-12-2010 06:18 AM
Carrier Furnace Error Codes spcook HVAC 4 10-14-2009 09:44 AM
