Old 10-16-2011, 12:15 PM   #1
Carrier-No Response to Thermostat Signal
I have a Carrier Model 58GFA130 furnace and this morning when I turned up the temperature at the thermostat the furnace didn't respond. I checked to make sure the pilot light was on and it was and the vent blower motor wheel was turning slowly. I disconnected the thermostat and crossed the signal wires and still didn't get a response. It didn't feel like there was any electrical current at the control wires as I thought there might be a small spark when they were crossed.
Not sure what to check next?
Thanks for the help.
CottagerRenoguy is offline   Reply With Quote
Old 10-16-2011, 12:46 PM   #2
Professional
which wires did you cross? R and W? next step is to check for 24V between R and C at the control board.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-16-2011, 02:09 PM   #3
Hi,
Ii did cross the red and white wires. I can't seem to locate a control panel on this furnace where should I look and what does it look like?
It's about a 1995/6 vontage furnace.
Old 10-16-2011, 02:17 PM   #4
Professional
Your furnace may not have one. Normally they would be found in the blower compartment. If possible post some pictures.
IT IS WHAT IT IS
Old 10-16-2011, 03:45 PM   #5
Houston204's Avatar
It is on the blower...
Houston204 is offline   Reply With Quote
Old 10-16-2011, 03:45 PM   #6
Hi, I'm not able to post the pictures to this site. I did take another detailed look throughout the blower compartment and there is n't a control panel on this unit. I've done some limited work on furnaces and I do know what one of these generally looks like.
Any thoughts on what I should do next?
Old 10-16-2011, 03:49 PM   #7
Thanks, just saw the diagram and have located the panel. I'll check for 24volts.
Cheers
Old 10-16-2011, 03:51 PM   #8
Professional
Well, scoffing to the picture Houston posted it should have one as he pulled the picture he posted from a manual for your furnace.
IT IS WHAT IT IS
E2 code on Carrier OMTSTAT_3 thermostat strikeeagle HVAC 13 05-15-2011 02:42 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Carrier Infinity Thermostat "Staging" Adrianjohnm HVAC 2 12-11-2007 02:20 AM
