Carrier Model #FV4BNB006 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 12:56 PM   #1
I have a Carrier Heat Pump that the blower motor stopped working. It is a verible speed motor and and has a cotrol module attached to it. I had someone check it out and he hooked up a tester to it and had the gotten the motor to start. He said that the module was bad and replaced it. The module didnt take care of it and said the motor was bad... The motor to my understanding is only sold with the module and is about $1500. My question(s) is if, the motor is bad then why did it start when the tester was hooked to it. The motor does act like it wants to go at this point but goes back and forth. How can I test the motor to verify it is bad? And if it is, is it only sold with the module and how much should it cost? Thank you, BBonefied
OK... I see that most of you have said that its probably the wrong module...
the original module has a tag with;
GE 3/4 Hp
01/10/03
DG02 015JOC
The replacement has;
RMOD46AE244
HP .75 VOLTS 240 AMPS 6.8
PH 1 FREQ 60 ROTATION CCW
FOR MOTOR PART NUMBER HD46AE244 (this number is on the motor)
on another sticker on the new module
GE ECM Motors by REGAL-BELOIT
ECM2.3
DG04
3/4hp 120/240v
5/13/2009 14 C03JC6
at a loss thanks for all of your responses
BBonefied is offline   Reply With Quote
Old 01-18-2010, 01:04 PM   #2
Probably used the wrong motor module. Carrier has 3 modules and you have to use the correct on or the motor will not function. The modules are identical but the part numbers are different.
SKIP4661 is offline   Reply With Quote
Old 01-18-2010, 06:08 PM   #3
An old Tradesmen
Rewards Points: 7,414
Yep.
If the tester ran the motor. Then the motor isn't bad.
The tech might have been given the wrong module by the distributor.
He needs to go back and get the correct one.
Old 01-18-2010, 06:21 PM   #4
Tester gives input to the module doesn't it guys. Motor ran so module and motor are good. Problem is the control board.
Old 01-18-2010, 06:29 PM   #5
An old Tradesmen
Depends which tester he used.
Many just send input to the module to run full speed.
Some times the module will respond to full speed input. But won't respond to a slow start input.
Very few VS motors actually go bad.
There is a way to test the motor only( 2 ways actually).
But, the one way will knock you on your butt pretty hard if you slip up. And I mean hard.
OP: How old is your air handler. Less then 5 years, the motor and module are under warranty.
Old 01-20-2010, 05:30 PM   #6
Which was it, wrong module or bad circuit board?
Old 11-19-2011, 08:42 AM   #7
Curious on fix
Im wondering what was your fix? Im having same problem n tech says its the motor n quoted over $1000 im having a hard time believing its motor so any help would be great
MAFV112 is offline   Reply With Quote
Old 01-04-2012, 03:39 PM   #8
What the quote price on a carrier circuit board and defrost board serial number # fv4bnb006
cfito1 is offline   Reply With Quote
Carrier Model 58MVP inducer motor deanray HVAC 11 11-19-2010 04:33 PM
Carrier Model 58 PAV Furnace ccmyers2 HVAC 4 12-02-2009 08:13 PM
Carrier Furnace Model 58PAV error code 34 ColdInNJ HVAC 2 02-04-2009 08:38 PM
