Carrier Model 58rav095-12 Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 11:09 AM   #1
carrier model 58rav095-12 furnace
My furnace will cycle to ignition and the flame will burn for just a second and turn off. What could be the problem?
lwooly242 is offline   Reply With Quote
Old 12-19-2010, 11:19 AM   #2
dirty sensor is the first spot to check.
hvaclover is offline   Reply With Quote
Old 12-19-2010, 11:33 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
Flame sensor, sits in front of the left burner, should look like this one, clean it with fine emory paper
Old 12-19-2010, 11:55 AM   #4
cleaned the sensor. Now it will cycle to igintor on but not going any futher.
Old 12-19-2010, 12:27 PM   #5
cleaned the sensor and reinstalled. Furnace will cycle thru to ingniter on and shuts down.
Old 12-19-2010, 12:33 PM   #6
Gonna meed a volt meter now...Got One? and do you know how to use it?
Old 12-19-2010, 12:51 PM   #7
ok boss listen closely. theres a blinking led light on the control board. its going to blink 3 times fast and 1 slow which means code 31. on the back of your front panel its going to tell you thats its you pressure switch failed to reclose. now if this is happening then its one of 2 things you have a bad pressure switch or your control board is bad. I have the same problem with 1 to.
hvac kid is offline   Reply With Quote
Old 12-19-2010, 12:53 PM   #8
can you take a picture of the pressure switch for us? its located next to the inducer motor it should have a red hose going to it.
Old 12-19-2010, 12:57 PM   #9
Yes I have one and know how to use it
Old 12-19-2010, 12:58 PM   #10
guess he does not have a camera either
Old 12-19-2010, 01:02 PM   #11
do you have a manometer?
Old 12-19-2010, 01:02 PM   #12
I'll defer to Hvackid since it is the courtesy we extend to new comers.
Welcome Hvackid.
The Following User Says Thank You to hvaclover For This Useful Post:
lwooly242 (12-19-2010)
Old 12-19-2010, 01:07 PM   #13
Hmmm this ought to be interesting....an HO with a manometer....
Old 12-19-2010, 01:21 PM   #14
do you want to help hvaclover or just make fun of me wanting to fix my problem.
Old 12-19-2010, 01:22 PM   #15
If the pressure switch is the problem you will be able to measure 24volts to furnace chassis ground on the incoming terminal...
No I don't want to make fun of you.
I was trying to be polite to hvackid.
Carrier Cobra Gas Furnace Problem carriercobra HVAC 13 12-30-2009 11:47 AM
Carrier Furnace Problem... cornation71 HVAC 3 12-10-2009 07:52 AM
Mister 50 Humidifier on Carrier Furnace alancs68 HVAC 0 12-06-2009 08:32 PM
Carrier furnace fan wouldn't shut off claymthomas HVAC 5 01-21-2008 06:39 AM
Putting a new Motor in a Carrier Furnace... Wiring issues cbrent HVAC 3 10-08-2007 06:08 PM
