Carrier Model 58 PAV Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 05:57 PM   #1
My home is heated with Carrier 58 PAV furnace unfortunately not working.
When connectors are held tightly in to electric control circuit box, the heat comes on and everything works properly. As soon as you let go, it turns off. The plug in connectors are not damaged and appear to be in good shape.
Thanks for your help!
ccmyers2 is offline   Reply With Quote
Old 12-02-2009, 06:04 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,862
Faulty circuit board. They had LOTS of them with bad solder connections.
Old 12-02-2009, 06:17 PM   #3
Thank you Yuri. Any idea where to buy circuit boards at a good price.
Old 12-02-2009, 06:47 PM   #4
Hvac Pro
yuri's Avatar
Not for Carrier. The replacement board may be a tricky retrofit model. Gotta be REAL careful to read the instructions and not stick the adaptor harness on backwards and break some pins. The instructions are a bit vague.
Old 12-02-2009, 08:13 PM   #5
Thanks again Yuri.
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 05:16 PM
Carrier Furnace Model 58PAV error code 34 ColdInNJ HVAC 2 02-04-2009 08:38 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 12:00 AM
