-   -   Carrier Model 58 PAV Furnace (http://www.diychatroom.com/f17/carrier-model-58-pav-furnace-58369/)
ccmyers2 12-02-2009 05:57 PM
My home is heated with Carrier 58 PAV furnace unfortunately not working.
When connectors are held tightly in to electric control circuit box, the heat comes on and everything works properly. As soon as you let go, it turns off. The plug in connectors are not damaged and appear to be in good shape.
Thanks for your help!
yuri 12-02-2009 06:04 PM
Faulty circuit board. They had LOTS of them with bad solder connections.
ccmyers2 12-02-2009 06:17 PM
Thank you Yuri. Any idea where to buy circuit boards at a good price.
yuri 12-02-2009 06:47 PM
Not for Carrier. The replacement board may be a tricky retrofit model. Gotta be REAL careful to read the instructions and not stick the adaptor harness on backwards and break some pins. The instructions are a bit vague.
ccmyers2 12-02-2009 08:13 PM
Thanks again Yuri.
