Carrier M/ 48EP008 - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 01:14 PM   #1
carrier M/ 48EP008
condenser fan blade keeps breaking
motor mounted in cage with rain guard
drhvac is offline   Reply With Quote
Old 08-11-2011, 01:33 PM   #2
JJboy's Avatar
Can you post some pictures?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-11-2011, 04:08 PM   #3
Make sure that the four bolts holding the motor bracket are tight. It may be necessary to replace them. Also check your blade height. Keep the tip of the blade about an inch up above the opening. The sheet metal used on these units is too thin. So its easy for the fan to shift around and cause the blade to strike the shroud.
Master of Cold is offline   Reply With Quote
How to check secondary heat exchanger on Carrier SXC? Vaandjay HVAC 3 12-19-2010 12:27 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Product Advice - Trane or Carrier 99Problems HVAC 5 05-28-2009 07:23 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 05:20 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
